AttributeRangeFilter set new attribute to whatever the output port is
  • February 15, 2021
  • 32 views
Hi
Is there a way to have the AttributeRangeFilter create the Output port names in a new attribute that's called like '_attrRangeFilterOut' and the values being whatever the name of the output port is?
So instead of having the AttributeRangeFilter followed by a bunch of AttributeCreators which basically sets the new attribute 'range' to the value that's similar to the output ports of the AttributeRangeFilter, is there a way to just have the AttributeRangeFilter do that for us?
AttribteRangeFilter
Best answer by nielsgerrits
Yes, it is called the AttributeRangeMapper.
nielsgerrits
  • February 15, 2021
  • February 15, 2021
Thank you!
nielsgerrits
joey wrote:
Thank you!
