Hi, i try to extract a map extend from arcgis. I need to create a polygone with the map extend. Not the data extend. Can you help me ?
  • October 20, 2022
  • 3 views
hugues
JennaKAtSafe
Hi @hugues​, could you further elaborate on this use case? If you're looking to extract a certain area of your map based on polygon (boundary) the Clipper might be what you're looking for.
