How do I place one autocadblock on multiiple points?
  • June 30, 2023
  • 44 views
morja
Good morning from Vienna!
This might be quite an easy task for advanced fme-users, but I have not too much experience working with fme. I have a task to read ifc-files and use the ifc-space information and location for write to dwg-files. I have one autocad-block as a template to be placed into the center of each room. So my idea is to derive the centerpoint of the footprint of each room and use those xy-coordinates for the autocadblock-x and -y. I just can't find a way how to merge both datastreams... FeatureMerger-Transfomer? but what data can I join the two streams on?
Thx for your help!
ifc2dwg with autocad-block template
nielsgerrits
Forum|alt.badge.img+64
This can be done using the DwgStyler transformer. If you need more help please elaborate what you have.
morja
  • June 30, 2023
Thank you so much!
This is allready a big step forward. I am now working on the right way to hand over attribute-data from the ifc-file to the respective text-attributes within the autocadblock. I am sure I can solve that...
nielsgerrits
Thank you so much!
I must admin I've never tried that, so I can't tell you how to do it from the top of my head. It is advised to create a new question if you have a new one.
