Invalid geometry (INVALID_CLIPPEE_GEOMETRY) passes GeometryValidator
  • March 29, 2023
  • 171 views
so_much_more
I am using the clipper to clipp some polygons. It failed with the rejection for 3 features as INVALID_CLIPPEE_GEOMETRY. But when i run the same rejected features through GeometryValidator with issues to detect "all" the same features pass.
Resolution is in meter. Node 0 and 1 are almost identical which causes the rejection i believe. But how can I setup FME to catch this duplicate of nodes ?
0: 575677.0999999503, 7032470.989999999
1: 575677.0999999512, 7032470.990000001
2: 575683.7099999504, 7032482.779999996
3: 575677.0999999503, 7032470.989999999
Forum|alt.badge.img+46
  • March 29, 2023
Within the Duplicate Consecutive Points test you can set a tolerance that will pick up points that are close but not exact copies.
