Create empty list and append to it "manually"
so_much_more
I am running a verification process and there can be one or more validation errors to my data for each feature. I would like to define my own error messages and push them to a list so i later easily can combine an error report.
To solve it I am thinking of using lists. But i cannot figure out how to create an empty list instead of an attribute.
I am thinking to have a list looking somthing like this:
errors{0}.height: "Negative values are not allowed"
errors{1}.height: "Value must not be empty"
errors{0}.quality: "Quality code invalid"
errors{1}.quality: "Quality code must not be empty"
errors{0}.bbox: "Feature is out of bounds, check coordinate system"
I hope you get the idea.
Later i want to use the list to report all the errors each feature might have.
But how can i define an empty list so that i can later populate it with values as the feature go through a step of testst? Can I use Feature manager to make my test and add the validation result to the list?
so_much_more
  • January 4, 2022
I think I solved it myself actually if someone out there does not have a smarter way to do it.
By running the validation steps in parallel instead of chaining and write the verbose error using the AttributeManager. I can in the end of the process use the ListBuilder to create a list by grouping the features with their ID.
It will be an awfull a lot of AttributeManagers (one for each potential error!)
Maybe using python is a better way to handle it?
JennaKAtSafe
Hi @so_much_more​! I would assume there is some type of query transformer in your workspace to verify the transformation. In that case would it be an option to generate a list from that transformer and connect an AttributeManager to customize the message? How are you currently assigning/defining your error messages?
These articles and past posts might be helpful as well
so_much_more
  • January 5, 2022
Hi Jenna and thanks for your reply and supplemented links.
Most of my validations are very basic and made by a tester or attributeManager. Using the attributeManager to apply verbose messages to a field. A few of the spatial tests i am doing with existing transformers I think/assume can output a list as you say.
I played with the python caller and think that might be my best route as I can append errors based on category to a python dict after with a serie of "if this..." append <error message..> .
In the end I assume i can combine all lists and exlode them into a table to be used in my result rapport in the end.
