i3s Writer - Appearance
  • September 4, 2019
  • 30 views
davidrasner5
Forum|alt.badge.img+4
Hello,
This maybe more of a ArcGIS question, not sure. I'm hoping someone can give me some hints?
I'm trying to set colors and shaders for i3c scenes, but can't figure it out:
  • The FME Export looks fine in ArcGIS:
  • But gets overriden in a web scene?
The ESRI validator complaints about texture definitions:
Metadata.json validation:
        No issues were detected.
3dSceneLayer.json validation:
    Warning: Missing Value:
        heightModelInfo
        attributeValues
    Information: Deprecated:
        ZFactor
Statistics validation:
Node validation:
    Error: Missing Value:
        For node 0 could not get property textureDefinitions.
        For node 1 could not get property textureDefinitions.
        For node 2 could not get property textureDefinitions.
        For node 3 could not get property textureDefinitions.
END OF VALIDATION REPORT
  • Pretty sure the model doesn't have any textures...
davidrasner5
  • September 4, 2019
After some trial and error:
  • Same file, FME -> GDB and publishing from ArcGIS:
Looks perfect.
So, it seems to be something about the FME writer.
  • This is in FME 2020.0, by the way.
