ODATA
  • February 5, 2020
  • 5 replies
  • 62 views
perry
Hello,
I'm trying to connect to the cloud with a HTTPCALLER.
I received an URL, Username and password to connect to ODATA/MSPROJECTS (Office365).
When I run the workspace I get the message:
HTTPCaller(HTTPFactory): Received HTTP response header: 'HTTP/1.1 403 Forbidden' from 'https://XXX.sharepoint.com/sites/pwa/_api/Projectdata'
How can I connect? do I need additional software? do I need to use an other transformer (ODATA?)
Please help, thanks
perry
  • February 10, 2020
@itay
Hello Itay, can you please give me some hints to connect FME with odata/msprojects? I've tried several transformers and connectionstrings without result. According to the accountant of MSPROJECTS FME has all the privaleges needed to connect with MSPROJECTS.
perry
  • February 12, 2020
@daleatsafe
Hi Dale, can you please help me?
perry
  • February 13, 2020
I've found the solution.
The url I triggers a popup. So I had to go 1 level furter. After redirecting the url I managed to establish the connection.
perry
  • February 20, 2020
unfortunately I was a little too optimistic:
I still have no connection with SharePoint MSPROJECTS.
I have tried the web service Microsoft OneDrive (Graph) also without result.
Is there any support or hints available to connect with SharePoint?
itay
Forum|alt.badge.img+18
  • February 20, 2020
@itay
Hello @perry apologies for not answering but I haven't been around much lately on the forum.
I would suggest creating at ticket at Safe to help you with this issue, if you haven't done so far.
Alternatively you can use the chat option, I always had good ppl helping me out.
Cheers,
Itay
