Hi!
I have this environment: the desktop version of FME is different from the server version (server: 2017 and desktop: 2016).
Is possible to create a workflow using FME 2017 and save this workflow as "FME 2016"?
Or when i start FME 2017, is possible to configure to use only "FME 2016"-compatible transforms/readers/writes (some type of settings to show only 2016 transformers etc)?
The solution I am using is to have both versions installed: FME 2017 and FME 2016.There is no problem to have both versions installed. This question is more of a curiosity that I have.
Thanks!
No, that isn't currently possible.
Having several versions of FME installed simultaneously is the "best practice" solution.
