I have a c# application that runs fme translation but how can I know if the translation was successfully or not?
How to know if a translation was successfully or not
Best answer by david_r
You can also use the workspace shutdown script to write out the translation status.
Sample Python shutdown script that will write either "SUCCESS" or "FAILURE" to the text file named <workspace filename>_status.log
import fme
message = 'SUCCESS' if fme.status else 'FAILURE'
log_filename = fme.macroValues['FME_MF_DIR'] + '/' +
fme.macroValues['WORKSPACE_NAME'] + '_status.log'
with open(log_filename, 'w') as statuslog:
statuslog.write(message)
There's a lot if interesting stuff in the 'fme' module that you may want to in include in this file:
