Background map request to the WMS server returns incomplete set of layers
  • April 25, 2018
  • 34 views
Hello,
I am trying to add a background map in FME Data Inspector. I am using a WMS server which returns an XML having a following structure:
<WMT_MS_Capabilities version="1.1.1" updateSequence="0"><Service></Service><Capability><Request></Request><Exception></Exception><Layer></Layer><Layer></Layer></Capability></WMT_MS_Capabilities>
We have two <Layer> sections. It is not visible here, but they contain <SRS> tags and a set of nested <Layer> tags, which are used to populate the Layer List in WMS Parameters. It seems however, that the Layer List is missing nested layers from the second <Layer> section, only the ones from the first section are loaded.
Could you please make sure that complete set of layers is loaded from a WMS server?
Best regards
Forum|alt.badge.img+62
Any chance you could share the WMS url with us so we can have a closer look?
  • April 26, 2018
I can't send you URL, but I can send you the XML (I have removed some data not related to this issue wmsashx.xml)
Only the following layers are loaded into Layer List
44d30d35-016a-4004-81db-c637774546cc
005e9b1d-548d-469b-a226-4919e5d32bd0
ed75af73-3658-4ea9-841a-57ce7a876a37
906d2cff-60c8-4791-8506-5224090290de
  • May 7, 2018
Has anyone been able to reproduce this issue with the xml I have sent?
