Hi FME'ers,
on the FeatureMerger, I get the rejection code 'EXTRA_REFERENCE_FEATURE. Does anyone know what this could mean?
The problem occurs on a Supplier object, coming from AutoCAD Map3D, with OD objects. It merges with an Oracle table, using two attributes. When checking visually, the attributes should match, but it doesn't come that far because of the rejection.
