Hello
Could not able to write “Esri Geodatabase (File Geodb Open API)” facing Error Geodatabase Error (-2147219884): this so frustrating form last 2 days i am suffering from this issue.
Hello
Best answer by nielsgerrits
This is probably caused by an attribute name which is in a list of reserved words (like DATE, ORDER, UPDATE).
Or an attribute name interfering with Table Creation Parameters (like OBJECTID, SHAPE, DEFAULTS).
Also see this topic.
