Undefined macro `VALUE_ATTR_ALIAS'
  • November 30, 2015
  • 15 views
when running my workbench the translation failed. I get the the following message: "
Starting translation...
Undefined macro `VALUE_ATTR_ALIAS' dereferenced in file `C:\\Users\\myPC\\AppData\\Local\\Temp\\2\\wb_template_1448871318470_1968\\wb-xlate-1448874512179_1968'
Program Terminating."
Does anybody know how to handle this issue?
Thanks Kathrin.
fmelizard
Forum|alt.badge.img+21
  • December 1, 2015
Definitely a bug of some kind. Can you visit our support form and send in the workspace and the full log and we'll take a look. Sorry about this one.
gio
Forum|alt.badge.img+15
  • December 3, 2015
This mostly happens when u reference a parameter wich at that point has not been created yet.
I encountered this error before, and it always was due to malstructered script.
If i'm not mistaken, you can get this using variable setters and readers.
I suggest checking the structure of your script.
bo
Forum|alt.badge.img+10
  • December 6, 2015
@kborgwardt,
I encountered the issue this afternoon as I was tinkering with python code written by someone else. It turned out that in the commented-out sections, there were references to the offending variables in the form of $(my_var). I guess even though the references are commented out in python code, FME interpreter still treats $(my_var) as a special variable or parameter.
I removed the "$(" and the workspace worked now.
Hope this helps.
Bo
