Run FME transformer after processing of a writer
  • December 18, 2017
  • 453 views
In my workbench, I am writing a file which i want to send as attachment in an email notification from the same workbench. How can i control my FMEServerEmailGenerator to work if only the file is written?
Note: I am using Fanout process in writer.
Best answer by nielsgerrits
I know 2 ways to do this:
- WorkspaceRunner. Creator to start WorkSpaceRunner. First WorkSpaceRunner to process data. Second WorkSpaceRunner to mail attachment.
- FeatureWriter. Use Summary feature from FeatureWriter to initiate the next Transformer. I often use a Holder to prevent starting the Transformer after the FeatureWriter before all features are written.
I prefer the FeatureWriter because this way you can keep it in one Workspace.
The downside of using a FeatureWriter in server is that the field numFeaturesOutput in the job summary is not handled correctly. Using a classic writer this number tells the number of written features correctly.
nielsgerrits
Forum|alt.badge.img+64
  • December 18, 2017
  • December 18, 2017
Thanks for the answer.
