extrude Wall
  • January 30, 2014
  • 11 views
venu
Forum|alt.badge.img+5
I have walls line on top with ground height, please can any one help me.
Line is have 2 vertex.
The line z value start node from sea level 18 and end node from sea level 15.
Ground height from sea level 8.0..
  • January 30, 2014
How about creating 3D polygons (walls) and then transforming them into faces?
The FaceReplacer can be used to transform polygons into faces.
Takashi
venu
  • January 30, 2014
I am creating 3d polygon with extrude transformer using with ground value
  • January 30, 2014
You mean the Extruder transformer (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/extruder.htm)? I think it has transformed a line into a surface geometry (not a 3D polygon).
