DLIS support?
DLIS stands for Digital Log Interchange Standardand is widely used in Petroleum industry.
The standard is described here http://w3.energistics.org/rp66/v1/Toc/main.html
Couldn't find any library for processing that format.
mark2atsafe
Forum|alt.badge.img+44
  • August 19, 2016
Hi - from our records I can see that we considered implementing this format, but decided not to.
I do see that there is a specification for the format here - http://w3.energistics.org/rp66/ - but no library that I know of.
I think you have a few of options here:
1 - Contact safe.com/support and register your interest. The reference number to quote is PR#50713
2 - Add it as an idea on this knowledgecentre - so we can gauge general interest in the format
3 - Use the FME plugin API to try and develop a solution yourself. See safe.com/developers to see how to sign up for our developer program to provide you support and test licenses
I think it's unlikely we'll implement this, because that comes down to the level of interest and you're only the second person to have asked for it.
Hope this helps
  • August 23, 2016
Hope this helps
Thanks, idea posted https://knowledge.safe.com/content/idea/32644/dlis-support-1.html
