To give port Number from Command Line in Smallworld
I need to Dynamically change the Port Number in Workbench from Command Line before starting the FME workbench based on the Smallworld session
Best answer by erik_jan
You can publish the parameter that contains the port number (right click the parameter and create user parameter) and then use the parameter on the command line, like:
fme.exe myworkspace.fmw --portparameter 3000
erik_jan
Forum|alt.badge.img+18
  • March 22, 2018
  • March 22, 2018
Thanks,
Is there any chance to define the Port number from CMD line like mentioned below
erik_jan
  • March 22, 2018
vioarx wrote:
Thanks,
Sorry, but never seen that notation.
An option is fme.exe myworkspace.fmw --portparameter %1
This will prompt for a value.
  • March 23, 2018
Thanks for update
