Convert excel csv x,y meter coordinates into dwg file format
  • November 13, 2017
  • 190 views
New to FME: need to convert excel csv x,y meter coordinates into dwg file format
erik_jan
Forum|alt.badge.img+26
  • November 13, 2017
If you open the settings of the csv reader, you can set the datatype of the x and y attributes to x-coordinate and y-coordinate.
FME will automatically create a point geometry out of x and y in that case.
Then you can write the features with point geometry to a DWG writer.
  • November 14, 2017
Thank you for a quite clear answer; it seems simple, but as Im new to FME.... I'll try this path; it should resolve what I need.
