SQL - Index columns
  • July 28, 2016
  • 103 views
Hello,
I'm using a workbench with a workspace runner. The workspace translates files into MS SQL tables. I would like to index some of the columns once all the files have been processed.
Can you please help?
Thanks, Moni
  • July 28, 2016
You can use the SQLExecutor to create the indexes, e.g.:
CREATE INDEX index_name ON table_name (column_name)
If you want to make sure the SQLExecutor is executed last, use e.g. a FeatureHolder and then a Sampler (1st feature) before the SQLExecutor.
You could also put the SQLExecutor into a child workspace and have it called with another WorkspaceRunner from the master workspace.
ciarab
Forum|alt.badge.img+9
  • July 29, 2016
@honkovam I second what david_r suggested to create the index like eg
but I usually put it into the navigator panel in the SQL Statement to execute after translation parameter if you wanted to cut down on having workspace runners
itay
Forum|alt.badge.img+18
  • July 30, 2016
Or just use the FeatureWriter, that is if you are using FME 2016, and after it the SQLExecutor
