I'm using ChangeDetector transformers and Tester transformers to compare two database tables and get modified records .now i need to get only those attribute values which have changed and not the entire record. Please help
thanks in advance
Best answer by sigtill
Have you looked at Matcher and if this Transformer can help you?
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
