Impossible to connect to FME Stroe for custom transformer
  • July 29, 2013
  • 25 views
I can't connect to FME Store through FME Desktop when adding custom transformer.
I am behind a proxy but the option "use system proxy settings" is checked.
I receive this error messagee:
Current connection to FME Server does not support HTTP 1.1 messaging.
I would like to try SmartCleaner_2013, is there an other way to get this transformer?
Thank you
Best answer by fmelizard
Yes, you can get it from here
fmelizard
Forum|alt.badge.img+21
  • July 29, 2013
  • July 29, 2013
Unfortunately, I have the same error message when I try to open it from the FME Store website. I saved it on my disk but on opening it tries to connect to FMS Store again.
