Select near features with specific query
  • June 28, 2015
  • 5 replies
  • 19 views
I have hospitals data (points) and trying to select the buildings (polygons) near to each hospital where the total people living within these selected buildings between 1000- 2000 persons...any idea how to perform that?
Thanks
  • June 29, 2015
Hi
If a straight line distance is enough, you can use a Bufferer and iterate (https://knowledge.safe.com/articles/Samples_and_Demos/Looping-within-a-Custom-Transformer) over different sizes until the number of inhabitants gets within range. I suggest converting your building polygons to points (e.g. CenterPointReplacer) and using the PointOnAreaOverlayer on the buffer.
David
  • June 29, 2015
Thanks David..I will try and let you know
fmelizard
Forum|alt.badge.img+21
  • June 30, 2015
Have a look at the NeighborFinder transformer,its not that easy at first to use but once you get it its a very powerful transformer for distance calculations.
See this page for examples: https://knowledge.safe.com/articles/Samples_and_Demos/Passing-attributes-between-features-in-close-proximity
Make sure you create a list on the resulting features to test for the number of ppl.
Itay
  • June 30, 2015
Hey Italy and thanks for the reply...somehow it works for me and I got the total population for the near plots, but how I can export the list of candidates matching the criteria...(each hospital the list of buildings selected by the NeighborhoodFinder)..Thanks
Judy
fmelizard
  • July 1, 2015
In case of a 1:1 relationship I would merge the selected buildings with the original building features to get the selection.
If a 1:N relationship exist you can choose to explode the list and then merge.
Itay
