gtransreprojector
  • December 5, 2012
  • 20 views
I'm trying to make TAB-files from a database and it's working but when i try to change coordinates from sweref 992015 to sweref TM with gtrans reprojector i get this  error:
I:\\Home\\Hans\\Prog\\Gtrans3\\gmat\\gproj.for(173) : run-time error M6203: MATH
- exp: OVERFLOW error
Execution traceback:
  from GPROJ_GAUSSKR in I:\\Home\\Hans\\Prog\\Gtrans3\\gmat\\gproj.for(173)
  from EXE_PROJ in I:\\Home\\Andalf\\Prog\\Gtrans3\\GATE\\GATEEXE.FOR(360)
  from EXETRANS in I:\\Home\\Andalf\\Prog\\Gtrans3\\GATE\\GATEEXE.FOR(186)
  from T_EXETRANS in I:\\Home\\Andalf\\Prog\\Gtrans3\\MAIN\\FOR\\GTRANS32.FOR(954)
Warning: not all FMESessions that were created were destroyed before shutdown.  This may cause instability
If i take the tab-files i've created without gtransreprojector, and runs in a new workbench with gtransreprojector the transformation works. I want it all in one workbench. What am i doing wrong and what do i need to think about?
Running win 7, workbench 2012 sp4.
Best answer by gabriel_hirsch
Perhaps you find the solution for this problem. If not, please read the newly updated FMEpedia page about GTrans: http://fmepedia.safe.com/articles/Samples_and_Demos/FME-and-the-Gtrans-coordinate-system-transformation-tools
I've contributed with some info about error handling.
gabriel_hirsch
Forum|alt.badge.img+12
  • April 24, 2013
