CREATE LOD2
  • February 13, 2018
  • 38 views
I want to create LOD2 objects from LAS file.
As input i only have 2D buildings as polygons, representing boundary of building, with no roof-ridges or other roof details, only polygons (without elevation)
I want to create roof-ridges and roof surfaces.
How do I use FME to make areas to represent roof sides? So i need the maximum and minimum elevation inside the boundary but how to do to make roof sides ?
I used a clipper between las and boundary and after a pointcloudcalculator but after i use a geometryreplacer i don't understand all geometries exit rejected why ?
And after it's necessary to use 3d Forcer, i need help !!
Thank you
Nat
daveatsafe
Forum|alt.badge.img+20
  • February 15, 2018
Hi @npleuchot,
I think the procedure described in the following article will get you the results you desire from the point cloud and building outlines:
Point Cloud to 3D Terrain Model with Buildings
