How do I automate DWGReader to skip this bad file?
ronmak
I have a workspace that reads data from a long list of DWG files and writes specific features to a SHP file. The status the drawings could be anything, including corrupt so I have Rejected Feature Handling set to Continue Translation. When the workspace runs, I can see in the log that some DWG files are skipped for various reasons. A new problem occurs when it hits the attached DWG file. It is a Civil3d file and the log shows that FME finds a resource to read it, but then it just sits there and nothing happens for a few minutes until I get an error.
For now I have deleted the file from the list, but it would be better if the workspace would simply skip it and go on to the next file. How do I do this?
Be the first to reply!
