excel writer filename from attribute
  • June 23, 2020
  • 6 replies
  • 211 views
raabster
Forum|alt.badge.img+4
Hi!
I'm trying to have FME to output an excelfile and use an attribute as it's filename. Can't get it to work! In the parameters settings for the writer I enter the folder in the "Destination Fanout Directory" and as the Fanout Expression i enter:
@Value(ATTRIBUTE THAT I WANT TO USE HERE).xlsx
This gives me one ".xlsx", that does not open, and one file with the correct filename but without a file ending (xlsx).
Anyone who can point me in the right direction?
Using fme desktop 2020.
UPDATE:
The error was my own fault. The attribute value contained a : (colon) which a filename can not include. Sort this out and the filename get produced as expected.
Best answer by raabster
Thank you @daveatsafe for your patience along the way!
daveatsafe
Forum|alt.badge.img+20
  • June 23, 2020
Hi @raabster,
What version of FME are you using, and what is the value of the attribute you are using for the filename?
raabster
  • June 24, 2020
Hi @raabster,
Hi @daveatsafe, I'm using FME(R) 2020.0.2.1 (20200511 - Build 20238 - WIN64). The attribute-name/header is simply E, and the value of the attribute is TEST.
Thanks for your answer :)
raabster
  • June 24, 2020
Hi @raabster,
so in my fanout expression is simpy: @Value(E).xlsx
and I thought that would produce the file TEST.xlsx
daveatsafe
  • June 24, 2020
Hi @raabster,
I'm sorry, I was not able to reproduce the problem. Would you mind adding a Recorder just before the Excel writer in your workspace? Run the workspace and send me the resulting FFS file, so I can test using your data. If you don't want to make the data public, you can send to me directly: .
raabster
  • June 25, 2020
Hi @raabster,
Hi @daveatsafe!
I found the problem. I intended to set the attribute E to TEST but I did not. So the old data was still there and that string contained a colon which a filename can not include. So the error was 100% my own mistake. Sorry to have botherd you but at least my problem got sorted :D
So all in all - it works :)
raabster
  • June 25, 2020
