AutoCAD DWG/DXF read as merged featuretyps and write as single featuretype
I have different DXF File with a lot of layers. I read them with the AutoCad DWG/DXF reader, filter and editing them.
For the better handling I read the files as merged featuretypes, but I need at the end the data with single featuretype. That means I need all layers from the file and not the merged.
How can I manage this with the Autocad DWG/DXF writer?
Thanks and best regard
Best answer by daveatsafe
Hi @joe_gerner,
Please open the Properties of the single output feature type, then click the triangle button beside the Layer Name box. Choose Attribute Value, then pick the attribute autocad_layer_name or fme_feature_type.
When you run the workspace, the output Layer will now be set from the attribute you chose.
daveatsafe
Forum|alt.badge.img+19
  • December 6, 2019
Hi @joe_gerner,
  • December 9, 2019
daveatsafe wrote:
Hi @joe_gerner,
Thx for your help :)
