Best Answer
Is it possible to create a hyperlink to an image url in a csv spreadsheet using fme?
Best answer by takashi
Hi @shanezentner, if you want to write a hyperlink into Excel spreadsheet, create an attribute suffixed by ".hyperlink" that stores the URL. e.g.
