Working with geochemical data - converting excel files to gdb feature classes. Zinc (Zn...) columns are automatically recognised as a z-coordinate and the data doesn't plot!
  • November 21, 2017
  • 51 views
I'm attempting to convert hundreds of excel files to geodatabase feature classes in a dynamic workflow.
What I've done:
In the generate workspace dialogue,
Reader - Format: Microsoft Excel, Dataset: my excel files (testing with 5 for now but will have hundreds in reality), Coord. System: UTM83-20. In the parameters, it correctly selects the Easting column as x-coord and Northing as y-coord but incorrectly selects the column "Zn_4A_ICPMS_ppm" as z-coord. I then change the type to "Number" for the first file (only file that is listed in the "Sheets to Read")
Writer - Format: Esri Geodatabase (File Geodb Open API), Dataset: my gdb
...with Dynamic Schema selected in workflow options, press ok.
In the writer parameters, I changed the Geometry to gdb_point and also the Schema Definition Name to fme_feature_type
When I run it, the log says that the translation was successful and all 5 feature classes show up in my gdb but only the first plots spatially.
In every excel workbook there's 1 sheet and in each sheet the column for zinc is automatically being recognized as the z-coordinate (except for the first file, which I manually changed to number). The zinc columns are all different: Zn_4A_ICPMS_ppm, Zn_XRF_ppm, Zn_ICPMS_ppm, Zn_AQR_ICPMS_ppm, Zn_4A_ICPOES_ppm
Does anyone have any suggestions to work around this? Is there a way to somehow set what columns will be recognized as the x/y coordinates if they have the same name (and maybe set that there is no z-coordinate)?
Thanks!
Best answer by laurawatsafe
Hi @badams,
That changed setting from the first sheet probably isn't applying because the Zn_.. column name isn't the same for all of your input files. Perhaps try creating the points within the workspace instead of relying on the reader for that. You could try adding a VertexCreator between your reader and writer to create a point from the Easting and Northing values and leave the Z value blank. You'll probably get the best results by setting the mode to 'Replace with Point'.
laurawatsafe
Forum|alt.badge.img+13
  • November 21, 2017
Hi @badams,
gio
Forum|alt.badge.img+15
  • November 21, 2017
schema is different.
You can read dynamicaly.
Change the zinc column to the z value after extracting it with a coordinate extractor. Remove z from points by using 2dForcer.
  • November 22, 2017
Hi @badams,
Thanks so much! @LauraAtSafe
  • November 22, 2017
Thanks for the input @gio I used LauraAtSafe's idea and it worked perfectly!
