Get only the first and last segment of every polyline
I have data with lines and polylines.. I’d like to have segment with 30m from the starting point and from the ending point (end minus 30). For the polyline I’d like to have only the first and the last segments. I’m using chopper (2 vertexes) to get lines from 2 vertexes but then I need to choose only the first and the last segments. The resultings segments should have the same angle of starting or ending segments of polyline. Any idea .. thanks
