How can I used an excel writer to populate a column based on the data in another column?
mbuske
I am trying to write a value to a column in an excel sheet called NEWCOUNT based on feature names located in the column LAYER. I was previously using an old writer (xls_ADO) which allowed the use of SQL but since that is no longer offered, I must use the xlsx writer. How can I use the writer's formatting parameters to do this?
  • November 3, 2017
Hi @mbuske
could you please give us an example? E.g. what value would you like to have in the second row NEWCOUNT cell?
mbuske
  • November 3, 2017
NEWCOUNT represents the new the number of records that a feature has in a .gdb. So for example, TERM_DET has 1371 records this month, and next month it may have 1374. I need to update the NEWCOUNT of TERM_DET each month. The position of NEWCOUNT will change because I add a new column for a new month.
gio
Forum|alt.badge.img+15
  • November 3, 2017
create new datecolumn and set to the new newcount attribute.
sort columns with datenames using attribute manager.
send to writer
  • November 3, 2017
If you have NEWCOUNT attribute on your feature, Excel Writer will write the value into the right column.
surbhi
  • November 7, 2018
I use a Feature Writer to write to a geodatabase and then to keep a record of the number of features created, I used the Summary Attributes functionality within Feature Writer and then a Date Time Stamper to write to a new row in an Excel sheet, which stores the date the process was run and the count of features created. The Excel sheet has a field for the TimeStamp and the Total Features Written.
