How to read Autocad anonymous block
  • February 14, 2014
  • 5 replies
  • 31 views
Hello everyone!
I have an autocad file that contains anonymous blocks.
I would like to be able to read them from FME 2013, meaning see autocad_block_name.
In autocad, by going to quickselect, I see various block's name like: *U248, etc
and I see on which layer these anonymous blocks are.
In FME, I have to use schema reader to find the same layer, but I have no informations of the anonymous block's name.
Can anyone help me? Thanks
tbs_gis_team
  • February 14, 2014
Enable format attribute on reader autocad_block_name should be enabled. Then use attribute filter to filter out block names
  • February 14, 2014
Hello TBS_GIS_TEAM! Thanks for the replay.
However, autocad_block_name is already enabled in my reader, just to be sure, I put an inspector right at the output of the reader and I can't find anything starting with * or with U248 in the FME Data Inspector.
The only thing that could be related to these blocks is the layer they are on, and I can only find that layer with the Schema Reader. But no sign of block name beginning with * or U248.
fmelizard
Forum|alt.badge.img+18
  • February 14, 2014
Are there any features in the file? Or only layer definitions ?
  • February 14, 2014
Hi Itay,
There are features in the file but nothing associate to the anonymous blocks nor with the layer .
The layer that is related to those anonymous blocks when I check Autocad, is only available when I use a schema reader in FME.
I stumbled upon the same problem this week. We are looking into the capabilities of FME to read dynamic properties within blocks and even read blocks within blocks but haven't found a solution so far. We even noticed that if you have a dynamic block FME doesn't store the original block name but the temporary block name that is generated by Autodesk Autocad when opening a dwg file with dynamic blocks.
To provide interoperability this is a nightmare :)
We would love to see this in future releases because it would be an addition to our BIM Use implementation (Drawing Review) in our drawing offices.
