The post title
POSTGIS Writer: Fanout for feature type [postgis_table_name] failed to find feature type template ''
is the error I'm getting in the FME log when I try to run a workbench which has already worked flawlessly a lot of times.
It looks to me a database-related issue (template?) but I can't understand it and can't find any solution. I have no fanout and database configuration has to my knowledge not changed. I did not even change writers configuration.
My FME version:
2015.1.1.0 (20150715 - Build 15515 - WIN32)
Any ideas on how to handle that?
