need to read MicroStation properties and write out a new file with different properties.
  • March 7, 2019
  • 22 views
dszarka
I have a MicroStation dgn file that I need to change the levels names, line styles, colors and weights to match our standards. Is there a way to read the attributes in one file and cross reference them in a excel spreadsheet or csv file and then write a new dgn file with the cross referenced attributes?
danilo_fme
Forum|alt.badge.img+45
  • March 7, 2019
Hi @dszarka
I suggest you to expose the Format Attributes from Reader:
For use another Reader ( Excel ) you can do a Merger Attributes ( FeatureMerger ) and the transformer AttributeManager to set the values for these attributes ( color, weight, etc.. ) from Excel.
Thanks,
Danilo
