How to create shapefiles for AutoCad
  • January 29, 2018
  • 35 views
Currently using AutoCAD 2017. Have a customer who needs shapefiles for a county dwg. I know these can be created in AutoCAD Map. Do you have a software that does this? If so can you briefly tell me what is does? Also what is the cost?
Best answer by fmelizard
Hi @sbhibbert,
FME can do both CAD (DWG) to Shapefile and Shapefile to CAD (DWG) translations:
Converting Shape to DWG how-to article
DWG to Shape how-to article
If you require further information, sharing a few more details will help the FME community help you. Please reply to this thread and provide additional details including:
  • A clear statement of the problem you are trying to resolve
  • The version of FME you are using, including build number and edition or FME trial?
  • A small sample of your data, or screenshots of the data in the FME Data Inspector
  • A description of your expected output, with screenshots if possible
  • Your FME workspace
  • Your FME translation log file
  • Any other information that may be useful to share
For pricing, please see https://www.safe.com/pricing/
fmelizard
Forum|alt.badge.img+21
  • January 29, 2018
Hi @sbhibbert,
