Best Answer
Orientation of PDF Output
  • June 6, 2018
  • 76 views
Good day,
I create one map per ship showing its track of the last month. The map is output as pdf (Adobe Geospatial PDF Writer). By default the page orientation is portrait. I would like to dynamically change the orientation to landscape depending of the map's bounding box (width/length). How can I do it?
Best answer by debbiatsafe
Hi @kat
You can use a Tester or TestFilter to route features based on the bounding box ratio (eg. if width greater than length = portrait, etc.) to an appropriately configured PDFPageFormatter. You will be able to determine the page size and orientation using the PDFPageFormatter.
debbiatsafe
Forum|alt.badge.img+21
  • June 6, 2018
Hi @kat
  • June 7, 2018
Hi @kat
Thanks. Working fine. I even don't need the PDFPageFormatter. I only create the pdf_page_size attribute.
deanhowell
Forum|alt.badge.img+24
  • July 15, 2019
Hello @kat, I am trying to do the same thing, so was wondering if you could do a screen shot of what you did to solve this issue please?
