Shape defined within template is not stored. Error
  • February 13, 2019
  • 5 replies
  • 74 views
garyb
I saw a very similar question to this from a couple of months ago where the poster managed to resolve it on his own, but his fix did not work in my case.
I'm reading from AutoCAD Map OD (multiple files) and writing to AutoCAD Map OD (single file). I've checked my template file and Shape File Folder Path and they all seem to be fine, so I don't understand this error or why my workspace won't run.
fmelizard
Forum|alt.badge.img+21
  • February 15, 2019
Hi @garyb Are you trying to create a template from your workspace and the source data isn't getting added? Can you attach your workspace here? If not, please send it to https://www.safe.com/support/report-a-problem/ Thanks!
garyb
  • February 15, 2019
Hi Dan. No I'm not trying to create a template from my workspace, the template I mentioned is a CAD file being reference in the parameters of the Writer. I tore this all down and spent most of the day working on it yesterday and it seems to be coming down to a single AutoCAD Block in the template file. When I purge it out the workspace runs fine and when I add it back in it fails. There's nothing unusual about this one block (very simple 4 lines and a string of text) so I can't figure out why it is a problem, but I do think I've got it narrowed down to that now.
fmelizard
  • February 15, 2019
@garyb Thanks for narrowing down the problem. Please send the template file, workspace, etc. to https://www.safe.com/support/report-a-problem/
garyb
  • February 15, 2019
OK, I have submitted it now. Thanks Dan.
ferhdfme
Forum|alt.badge.img+13
  • February 11, 2025
In my case, I had the same error and I solved it by removing the autocad_entity attribute with the transformer AttributeRemover before writing it in AutoCAD for the features whose value in the autocad_entity_visibility attribute was invisible.
