I am trying to mosaic several ECW images together into one large file in the latest release of FME 2020.
It is a very large file, according to FME it has a raster size of 1360000 row(s) and 1184000 column(s). And after the mosaic transformer has finished I get the following errors:
ERROR - ECW writer: Could not open compression task Output image size exceeds license
Â
ERROR - ECW writer: Failed to write dataset 'G:\\test\\test.ecw'. This may occur if you have insufficient privileges to write this file, or if insufficient disk space is availableIs there indeed a size limit with certain licenses? I couldn't find anything about this. There is also no reason why it would complain about privilidges or disk space for the output folder, as there should be more than enough space available on the disk.
How can I solve this error?
