Reading a .txt with WMS Links and publishing them to FME Server / ArcGIS ServerRest Interface
  • January 12, 2014
  • 10 views
schlomm
Forum|alt.badge.img+4
Hi all,
As you can see, I have a quite complex question. Some genereal information:
I'm using
  • Windows Server 2012
  • FME Desktop and Server 2013
  • ArcGIS Server 10.2
What I want to do: Using a Web Harvesting program, which searches on a OpenData-Site for accessible WMS Service, which I want to integrate in my WebMap.
The WebHarvesting program stores all WMS links in a txt file.
The links look like this: http://gateway.hamburg.de/OGCFassade/DE_HH_WMS_INSPIRE_A3_4_Bodennutzung_lokal.aspx?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=1.3.0
Now I want to use FME Desktop, which reads/parsed the line and after that, FME should publish these links to the FME or ArcGIS Server Rest Interface.
So....firstly my question would be: Is this possible?
And secondly: If it is possible, how to realize it?
Regards!
Best answer by david_r
yes, you can split up an URL in FME using a PythonCaller and the code previously posted here.
For publishing on ArcGIS Server using the REST interface, have a look at the HTTPFetcher / HTTPUploader / HTTPDeleter transformer.
David
  • January 13, 2014
David
