KMZ Elevation to DWG or CSV
  • November 22, 2018
  • 9 replies
  • 345 views
salwan
Dear Sirs,
I would like to extract elevation from a KMT or KMZ file from Google Earth! to use them in Autodesk Civil 3D (to DWG file).
Is that possible? I was looking and reading about the Google files inside the FME Knowledge center, but I couldn't find any topics which lead to the answer to my question!
I am very new to FME and this is my first time to use FME. I hope someone can help me with it. Thank you so much for your attention and your help.
Wishing you a wonderful day.
Kindly regards
Salwan Abbosh
danilo_fme
Forum|alt.badge.img+52
  • November 22, 2018
Hi @salwan
I believe thatyou can use the transformer CoordinateExtractor:
Parameters:
This transformer generate attributes: x,y and z.
Thanks,
Danilo
salwan
  • November 22, 2018
Dear Danilo,
Thank you so so much for your response. I will follow your steps and I believe I will be on the right track.
Again very appreciate your help.
Have a nice day
Kindly regards
Salwan Abbosh
danilo_fme
  • November 22, 2018
Dear Danilo,
Have a nice day
Kindly regards
Salwan Abbosh
Excellent @salman
Have you a nice day too
salwan
  • November 22, 2018
Dear Danilo,
I am afraid I need some help (my apology for disturbing you). I have done the following:
I have saved a selected area (using polygon) in google earth
I saved the file as KMZ ( the size of the file was very small about 657byets)
I created a new reader, I attached the google file to it with the needed coordinate system to the reader
The file contains NO Z value!
What am willing to realize, is to strip all the Z value from a large area on google earth
But it seems for me unclear how to put this issue together. I am very new for FME and this is my first use
I hope that you have some tips to manage that
Thank you so much for your help
Kindly regards
Salwan
danilo_fme
  • November 23, 2018
Dear Danilo,
Kindly regards
Salwan
Hi @salwan
Could you share here your kml file to investigate better?
Thanks,
Danilo
salwan
  • November 23, 2018
My Project XYZ.kmz
My Project XYZ.kml
Dear Danilo,
Thank you so much for your response very very appreciated. Here are the 2 Google Earth KML, KMZ files.
Thank you so much
Salwan
danilo_fme
  • November 23, 2018
My Project XYZ.kmz
My Project XYZ.kml
Dear Danilo,
Thank you so much
Salwan
Hi @salwan
Thanks yours files.
I open the files in FME Data Inspector and there are polygons in 2D.
In GoogleEarth = Do you want to get the Buildings inside your Polygons:?
I believe that is necessary to use the API for Google Earth to integrate with the features from GoogleEarth, using Python libraries - PythonCaller:
https://developers.google.com/earth-engine/
Thanks,
Danilo
salwan
  • November 23, 2018
Dear Danilo,
Millions of thanks for each moment that you spent on helping me. I don't want the building Z value but the profile of the roads and the existing Ground. I would like to extract the Z value to implement directly to civil 3d DWG drawing to create a surface which I can use to set up my model on it.
Regards,
Salwan
danilo_fme
  • November 23, 2018
Dear Danilo,
Regards,
Salwan
Hi @salwan
No problem! :) Thanks.
In my opinion is necessary to try to do this with API in Google Earth.
