Changing the name of an attribute in either a shapefile or excel file.
I am currently trying to merge two tables (one is a shape file with county polygon info and the other is a excel file with info about the county. My goal is to get the polygon info into the table with all the data. Both have essentially the same field (counties) but are named two different things. One of the files calls it counties while the other is a shape file that just calls it name and has the polygon data. What is the best way to merge these files or is it better to use ArcMap tools to do the merger?
