Hi guys! I'm new to FME. So far the software seems great but I'm having an issue with the data in my database persisting. I have a setup where I've created a CSV reader connected to a Postgres writer. When I run it, everything is ran fine without errors. In the visual preview it shows that the Postgres database has been written to. HOWEVER, when I do a Select * From database in a separate SQL command line, nothing is showing up in my tables. Its as if its not legitimately writing into the database. The connections are right, and this is happening on a local Postgres database I have running. I'm thinking there may be a step I missed? I did this all pretty straight-forward without tinkering with customizations. If anyone could assist or point me to a step-by-step guide for achieving this I'd really appreciate it. I have found similar guides on youtube but nothing for exactly CSV to Postgres. Thanks all!
Postgres Database not being written to
