Sumifs/Averageifs in FME
Is there a way of being able to replicate excel's sumifs/Averageifs functions in FME?
I have two tables, the first table has unique ID's and the second table contains data which I need to aggregate. Is there a transformer where I can use the unique values in table 1 to match against the data in table 2 to perform a Sumifs?
Thanks in advance.
owen
  • August 3, 2018
Hello, yes you can use the 'group by' function on the statistics calculator. Might need to join your tables, although not clear on that from your post. Owen
  • August 14, 2018
Thanks for your help!
