Revit export IFC reader not working on fmecloud
  • October 15, 2019
  • 7 replies
  • 41 views
jpvo
The reader IFC with data view for Revit greturns an error message when used on fme cloud:
Could not load module '/opt/fme-engine-2019/plugins/writer_keyword.so' : /opt/fme-engine-2019/plugins/writer_keyword.so: cannot open shared object file: No such file or directory
It's working just fine on desktop FME(R) 2019.1.2.0 (20190829 - Build 19630 - WIN64)
But not on FME Server 2019.1.2 Build 19630 - linux-x64
Any idea?
Cheers
Best answer by stewartatsafe
@jpvo yes, the issues has been resolved in FME Server 2020. If you launch the 2020 FME Server beta and republish your workspace then it should run. Note, you will still see some pretty nasty looking warning message which I am working on getting removed but they don't affect the translation.
stewartatsafe
Forum|alt.badge.img+9
Hi @jpvo. This should work. We are just digging into the issue further. I'll get back to you shortly.
jpvo
  • October 17, 2019
Thanks Stewart. Let me know if you need more details/data about the error.
stewartatsafe
It is definitely a bug. I reproduced it on Mac too. I am just waiting on the development team to investigate so I can give you timelines.
jpvo
  • November 5, 2019
@stewart.harper: any news on this bug?
stewartatsafe
  • November 5, 2019
stewartatsafe
jpvo
  • November 6, 2019
Very good news! Thanks a lot for your support!
