Hello,
I am trying to convert a DWG file with 12 separate solids to OBJ or DAE.
The conversion is perfect, but the output is 12 separate files - is there a way to convert it into one OBJ file?
I have just found another problem I can't resolve - in AutoCAD I have 6 layers, 2 solids in each layer.
would it be possible to export each element as a separate object? (they are grouped)
I would be grateful for some help ;)
best regards
