microstation DGN writer: how to set element fill type to opaque in FME
Best answer by lenaatsafe
Hi @edvdl,
thank you for your question.
You can control element transparency with igds_transparency format attribute (value 0.0 means fully opaque, value 1.0 means fully transparent). By default, all elements are fully opaque. However, to avoid black fill color, you need to set igds_fill_color which you shouldn't be required to know if you use 'by level'. We will file a PR with request to support 'by level' setting for fill color.
For now, please set igds_fill_color = 4294967295 using AttributeCreator to get 'by level' fill color.
