I have a sde writer. When I do an update or a delete the translation is succesfull. But when I do an insert I get the following error:
An error occurred while attempting to create a feature using the feature class 'db.schema.table'. The error number from ArcObjects is: '-2147220655'. The error message from ArcObjects is: {DBMS table not found [db.schema.table]}
The backend is postgres: PostgreSQL 10.5, 64-bit
Arcgis version 10.6.1
FME 2019.0 64bit also tried 2020 beta.
Writer mode: versioned edit session
