How can I create/update an Oracle table using a stored sql procedure instead of a FME-writer. The procedure already has a lot of validation and logging, so it would be a great advantage to use this instead of redoing it all in FME. Is this possible using i.e. SQLExecutor? If so, how to set it up in FME?
Creating/update Oracle table using a sql procedure in FME...
