Converting shape file to xml file
  • September 3, 2015
  • 327 views
I have a spatial dataset as shape file (.shp) and need to convert it into an XML file. Can we do that in FME?
Best answer by david_r
Hi
FME can read Shape files and write XML files, so yes, most likely unless you have some crazy complicated requirements.
Some general info here: David
  • September 3, 2015
Hi
