I am trying to update 3 fields for all records in a SDE SQL GDB versioned Feature Class (where building id = bulding id). I have seen several posts and help files but am not having success with the reader + attribute manager + writer or the reader + SQL executer + writer combo. Can someone advise on how best to set this up? Many thanks,
Updating all the records for a versioned SDE geodatabase from a table in an external SQL DB
